New Member
MattBithell
Message 1 of 2 (137 Views)
Export 2D Level Banding?
137 Views, 1 Replies
01-16-2013 01:46 AM
We use 3DC for basic cut/fill models and tend to use the same banding depths so in metre intervals from -10 say to +10. To remain consistent we like to keep the banding the same. I wondered if there was any way of exporting a banding set or colour scheme from project to project or surface to surface.....
autoMick
Message 2 of 2 (132 Views)
Re: Export 2D Level Banding?
01-16-2013 02:41 AM in reply to: MattBithell
Yes there is... go to the toolbox tab on your toolspace window. If you run UKIE or ANZ templates you should find under "additional tools" that you have "surface analysis - export to a file", and similarly to import to a file. I use this all the time and I recommend reading the thread that put me onto it: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Custom-color-range-for-surface-elevations/td-p/339635... In it you will find some useful tips from Andrew Puller on how to add a bit of flexibility.
Regards
- Mick
Infrastructure Design Suite Premium 2015 SP1
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
