Civil 3D Forum
Exploding featurelines to 3D Polylines
11 REPLIES 11
Message 1 of 12
jeff_rivers
2981 Views, 11 Replies
I have several featurelines that I wish to explode to be 3D Polylines (bad, I know, but it's a test for a way to get data across from our design group to our survey group).
Last week, in this drawing, I exploded a large selection of featurelines and they all became 3D polylines, preserving their elevation data. This week, I drew an additional set of featurelines in the same drawing.  When I explode them once, they lose all elevation data, becoming lpolylines at z=0.  Additionally, the Prospector shows me several errors: "breaklines not added to surface" or something similar.  Which is an odd result for the explode command.
What am I doing wrong?  Why did this work once but not a second time?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
11 REPLIES 11
Message 2 of 12
If it worked the first time and a second time on different data it does not work something has changed or the data is not the same. Have you tested a second time on the data that does not work and on a different computer?
Is it possible to attach the drawing?
In general: When exploding 3D feature lines you should get 3D polylines.
Karsten Saenger
Message 3 of 12
Thanks, that's what I thought too: Featurelines explode to 3D Polylines.
A co-worker just tried in a new, empty drawing not associated with a project.  He created a featureline with three vertices, with elevations 1, 2, and 3 respectively.  Exploded it once.  It turned into a polyline with all elevations at zero.
I did a similar test, but saved my drawing to an existing project first.  Created a featureline with four vertexes, all with different elevations.  Exploded it.  Now it's a polyline at z=0.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 4 of 12
jeff_rivers
in reply to: jeff_rivers
We've done more testing, and we have narrowed it down to the site.
Featurelines created in 'Site 1' explode to zero-elevation polylines.
Featurelines created in any other, new site explode correctly.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 5 of 12
AllenJessup
How are your Site Properties set?
Allen
Allen Jessup
CAD Manager - Designer
Message 6 of 12
jmayo-EE
Check your site's properties, 3D geometry tab and see if you are set to "Use Elevation".
John Mayo
Message 7 of 12
jmayo-EE
in reply to: AllenJessup
For the second time today,
John Mayo
Message 8 of 12
jmayo-EE
"Featurelines explode to 3D Polylines"
Note that this is partially true. FLines explode to 3d polys only if z varies. If z is constant explode will always return an LWpolyline.
John Mayo
Message 9 of 12
AllenJessup
If Site Properties is the answer and it happens in all drawings. You'll have to change it in your template.
Allen
Allen Jessup
Message 10 of 12
jeff_rivers
Great!  Thanks guys.
P.s. to AutoDesk- THIS WOULD BE HANDY TO MENTION IN THE HELP FILE SECTION ON FEATURELINES!
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 11 of 12
joantopo
Are you using "xplode" command  to get polyline from feature line?
Because I´m trying with this command and I get "invalid object".
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Message 12 of 12
Jeff_M
in reply to: joantopo
Use Explode, not Xplode
Jeff_M, also a frequent Swamper
Rail Community
