Civil 3D Forum
Exploding Assemblies
1 REPLY 1
mliverin
251 Views, 1 Reply
Hi all, new here, but have a question on assemblies.
I created a few different assemblies for my corridor for a stream reconstruction project, but when I moved my subassembly, due to a change in the depth, the subassembly exploded and I have to grab the grips and move them back (see pic).
Has anyone see this or experienced the before? If so am I doing something wrong or is this a glitch?
Also, I would like to stop my corridor before each culvert and not have it contour through it, is there a way to do this without creating multiple surfaces, one for each reach?
Mark
1 REPLY 1
MikeEvansUK
in reply to: mliverin
If you right click while selecting a sub assembly does it say "Clear Offset in Assembly"? if so do that. I  think you are selecting more than one sub-assembly when moving it.
Not really sure why you are changing the depth this way, it may be better to insert a generic link with hidden links to control the depth instead. This way you won't get this happening.
To create the surface as stated you have two options. Create Hide Boundaries at the culverts or multiple surfaces (multiple differing Top Codes)
I would create the corridor, add sections before and after the culverts thendigitise the hide boundaries over the culverts then add these hide boundaries into the model.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
