I've worked with LDD for 11 yrs. Last week the IT guys changed my PC to Windows 7 64bit, so I can't have LDD and I have to work with C3D. so I am following software tutorials.
for designing a road I created:
alignment ---> surface profile ---> layout profile (project line) ---> assembly ---> subassemblies ---> corridor ---> set target surface and frequencies
Corridor is created with daylights ,but I don't see existing ground in corridor section editor.
There is nothing about this in tutorial.
also I don't know how to calculate the volumes, in LDD after this stage we could calculate the volumes. i think in C3D I should do more for calculation.
please let me know the solution (for EG line).
Solved by andrewpuller3811. Go to Solution.
If you would send me your email address I can probably send you a pdf document that can answer most if not all of your questions.
Bill
wfberry AT bellsouth DOT net
Have a nice day!
Thanks Bill,
My work email address is:
shahrokh.sobhani@snclavalin.com
I created road cross sections, but still I don't have OG line.
Shahrokh
I can't find it, all layers in other menus are on.
Shahrokh
Wanted to throw this out there. I was/am having this problem every time I use the section editor, and I am doing a 'regen' to solve the problem. Hope this helps!
Jon
Try again as steve said, Go to Toolspace -> Surfaces -> Right Click on your EG surface and select Edit Surface Style...
Go to Display tab, choose Section from the View Direction: dropdown
In the Visible column left click on the light globe to make sure it is lit (on) click ok.
Go to section editor.
The section view styles and section styles only relate to how things appear in section views. The appearance of surfaces in the section editor is controlled by the surface style.
Thank you so much Andrew,
It worked and the problem solved.
Shahrokh Sobhani
Civil Engineer, P.Eng
SNC Lavalin Inc., Mining Division
Toronto, On, Canada M9C 5K1
hello there, guys am having a similar problem but the solution offered here doesn't seem one this side. if dis ghost can be awaken, could i get to have ma OG line somehow appear?
