Civil 3D Forum
Exisitng Cross Section Slope Labeling for Corridor
6 REPLIES 6
2435 Views, 6 Replies
Can someone point me in a direction on how to have exisitng cross slopes display on a bank of corridor cross sections...I see lots of posts on this but I am having trouble finding the answer.  The link below from help
Add a section view grade label only adds "A" slope label.....I want all of them in all of my sections.
http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/GUID-21890D53-6A5B-427F-88A0-EBD61C712EC-260.htm
6 REPLIES 6
i am using 2012
Jeff_M
You can auto-label a section, but, it will label ALL segments. Normally the EG will have many segmentss due to a grade break is created at every point where the section crosses a TIN line.
Select a sectionview, either right click or from the ribbon select SectionViewGroup properties, On the Sections tab of the dialog that is displayed, click the <Edit..> in the Change Labels column for the EG sections. Choose a Labelset that labels just the segment slopes.
You should end up with something like this (my EG TIN is fairly dense, perhaps yours won't be too bad):
Jeff_M, also a frequent Swamper
in reply to: Jeff_M
That is what I am after.   We just had a corridor resurveyed so the points and sections are pretty clean
Jeff_M
Glad I could help.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
For some reason our designer is having trouble with this....they are not displaying
Jeff_M
I'd be happy to look at your drawing if you'd like. It is probably too big to post here, you can email me direct at jeffm AT quuxsoft DOT com
Rail Community
