It appears to still be a issue in 2012. Here is an email from a collegue.
"We have a large number of drawings in our office that were produced using Civil3D 2011/12 that we need to send to a client who requires the drawings be sent with the xrefs bound into each layout and can be opened in Autocad. We are facing two major issues with this request which are as follows.
As a consequence we are having to open up the drawings that contain Civil3D objects and explode/remove these items. After completing this action, the bind xrefs function works correctly. As you can imagine this is taking a lot of time and effort for what should be a simple and quick process. Unfortunately, the client does not want to have to install object enablers to see the objects so we are fixed as far as the output.
Any suggestions/solutions would be greatly appreciated."
We have't used ETransmet with "AEC objects-exploded" in years. As near as I can tell, it's never worked. In fact, as painful as it it is we doin't even use ETransmit at all from C3D - it doesn't work. Even to get something to LDD. It's so disappointing. Hoiw can Autodesk create programs that are so incompatible with each other?
And it's not just the ETransmit feature, which is full of errors. The "Export to AutoCAD" feature is also very sub-par. And let's not even get into sharing C3D drawings with NavisWorks..... UGH!!!!!! Or 3DSMax....???? It gets worse and worse, the further along you go.
If anything, I'd expect programs made by the same company to interoperate. OK, they're terrible at collaborating with Bently. But collaborating with themselves....? What's happening, Autodesk?
Has anyone found a script or tool to explode AEC objects AND etransmit? This appears to still be an issue in Civil 3D 2014.
We found a method that appears to be working well for us. Although eTransmit doesn't dumb the C3D file data, I still use it to grab all of the XREFs, Plot Styles, fonts, etc. so we don't have to hunt & peck for them. Then we'll open the DWGs in C3D 2014 & EXPORT the DWG to 2000.
Since EXPORT prefixes the converted files with "ACAD-", I remove this from the file name so that the DWGs will still recognize the XREFs.
Hope this helps 🙂
Surfaces now explode, but cogo points still dont explode in Civil 3D 2017
Still not working. I'm using DWGConvert in DWGTrueview 2018.
It really sucks now that C3D 2018 and 2017 are not compatibile.
