rkmcswain
Message 1 of 2 (214 Views)
eTransmit oddities
214 Views, 1 Replies
11-14-2011 01:21 PM
C3D 2011 - up to date.  Wondering if anyone has seen this problem with eTransmit.
I run eTransmit and use a "transmittal setup" that does not include any extra files (fonts, textures, etc.), and yet my potential eTransmit file shows ±30 files - which includes fonts, textures, etc.
Sometimes I can go to the "Files Table" tab and manually uncheck the files I do not want. Other times, it only shows the 2 or 3 files I really want to include, but the status bar still says "30 files" and if I go ahead and run it, I get all 30 files. The "Files Tree" tab is always blank, nothing there at all.
A restart of C3D may or may not help, and then some days it seems to work just fine, and it's not drawing dependent as far as I can tell.... very inconsistent.
Valued Contributor
robert06
Message 2 of 2 (103 Views)
Re: eTransmit oddities
02-04-2013 03:45 AM in reply to: rkmcswain
Exactly the same problem with Civil 2013.
It seems that etransmit follows the current transmittal setup (the setup that was used last) and does not correspond to different transmittal setup selection. So running etransmit second time, when the wanted setup is already current (when activating the command) you'll get the correct result.
