I’d like to get some info about estimating time needed for a project. Nothing too exact is needed. How many hours per sheet do you guys build into figuring your time needed for a project using Civil 3D
Thanks for the help!
Hello Charles,
That's a very hard question to answer when you don't know the type of project and the types of sheets required. Are you only estimating output time, meaning the project is already designed, or are you estimating design and output? Who is doing the project and do they know how to use Sheet Set Manager to help with sheet creation? What type of hardware is involved, affecting the speed at which an operator can use the data. How many different files are involved. Lots of Xref's attached? Images? Civil 3D references?
If a template is already created and the design is done, it takes minutes to create the model views and place on sheets, but that's rarely the whole story.
Best regards,
Tim
I'm not wanting to get that deep in the weeds. Just any kind of rough information. Back of the envelope type estimate.
I will break a project down into tasks and then estmate the time for each task.
Example:
Create topography model from survey
Layout alignments and profiles
Create first run corridor and grading models
Create check plan sheets & review design
Etc.
Not all projects have all the same stages or even the same size, so I can't imagine a boiler plate cost estimate to cover all projects. Nor can I see how a simple cost per sheet can accomodate the many variables.
Very good question... Key is to keep track of your projects and the hours, even break that down into tasks. Highlight the project details, so a year or two down the road you have an idea. This will eventually give you a basis for your decision on answering. "How much time will this take to do". My usual response, It will take longer than you think it will.
Exactly!
Your Name
Your Name
It really depends on if it's a commercial project or residential subdivision project. In addition, it also depends the level of experience of your designer and drafter. Here are some good examples.
Plan and profile sheets = 1 hr to 3 hrs per sheet.
Grading Plans = 3 hrs - 2 days
DImensional Control Plan = 1 hr - 3 hrs
Storm Plans = 1-3 hrs
Water Plan & Profiles = 2-8 hrs
Drainage Area Maps = 2 hrs - 4 hrs
These are rough ball park figures but the site design will change several times before a first submittal. Then during the city review it will change a few more times also. It will end up taking months if a large commercial project with a few bldg or subdivision. I have several projects that the site has changed 6 times. That meant working thru all the sheets again. Anyways hopefully this helps.
Tony
CAD Manager
www.tonyscivil3dworld.blogspot.com
Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
"Plan and profile sheets = 1 hr to 3 hrs per sheet.
Drainage Area Maps = 2 hrs - 4 hrs"
... I would say this is completely based off of something where the process is well defined, all standards and templates are in place, and for something that is very straight forward. If I used your numbers for a complex roadway / infrastructure design and drafting project the budget would likely be exceeded in a hurry.
I've used 3 days per plan profile sheet for complete design (exg surface, design corridor, drainage, and extras (culverts, approaches, curb and gutter, drainage features, cosmetic features, etc.), drafting (prelim / conceptual) and design drawings, checking, review, and changes and updates after client review. It's a ballpark that gets us close on most occasions.
