Hi All,
I've just started work as an estimator and I'm new to CAD. I have a contour map on AutoCAD Civil 3D with contour lines. How would I be able to use AutoCad to estimate the quantities of fill that I can obtain for the site? Lets say that the highest elevation is 20 feet and I want to bring the site down to 10ft?
Thanks!
Hi Matthew,
Can you please PM me? I'm really new to CAD and I probably need a walkthru if you have time.
That kind of tutorial may be little beyond the scope of this discussion group. At least, it's beyond the time I have available at this moment. There are tutorials available in the user's Guide to help you unless someone else in here has the time to help you.
This is a link which shows how to make a surface from contours. It's tough to suggest any tutorial for your design surface without spending time with it to see your exact needs. Here is a link for grading tutorials.
if you've never taken a course, it would probably be worth taking a 3 or 4 days class if this is your job from now on. You could ask the instructor more specific questions about your project while you're there.
I suggest working through the following tutorial
http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/GUID-20DD4422-EC0D-4537-870F-96C62AD6679-60.htm
