Before I describe my problem, here is the background.
When I open the "LABELS" drawing, the data reference works. My problem is that when I open the "SHEET" drawing, the contour labels and spot elevations cannot find the referenced surface and just contain a string of 20 or so characters.
I already have a workaround. If I open the "SHEET" drawing, then open the "LABELS" drawing and save it, I can reload the "LABELS" drawing within the "SHEET" drawing and the problem is solved.
HOWEVER, I have a bunch of sheets that I want to publish, and publish does not work when you have to open the file and re-reference everything. Is there anyway to get this reference working correctly so that I do not have to open multiple drawings to get my data correct?
FYI, I have already tried resetting my data shortcuts project folder, validating data shortcuts, etc. in the "LABELS" and "SHEET" drawings.
Any insights are appreciated.
Tom
Civil 3D 2012, SP 2.1
