After identifying my contours on my surface I receive errors stating in the description "Breakline(........)not added-crossed a breakline at(......)"
My TIN surface is created anyways but when I tried to determine the cut and fill between my two surfaces the program doesn't let me compare them due to these errors.
Does anyone have an issue to this? Tried attaching file but ended up being too big.
If anyone could help, maybe e-mail the file and have a look at it to see what's wrong with it. Or give me a solution to this issue. Thanks ahead of time.
Solved by Joe-Bouza. Go to Solution.
Hello annramir
What version abd service packs?
What was the data source for the surface? This error is not that uncommon it means you have data with common xyz, and maybe a different z. Civil3d does not like common xy and different z.
Some screen captures of the surface and the data may be helpful to see
Is this related to your earier post with the corupt file? >>>HERE<<<
Joe Bouza
Heres some screen shots.
I'm not too familiar with C3D, but I'm using 2015 version. the data source were just several contours that I made into polylines and referenced them to the surface I generated.
I just added elevations to the contours but the boundary has no elevation.
Thanks for your help, I'm kind of at a standstill here with this project.
Joe Bouza
wow thanks Joe! I believe that worked, not really sure though, I got volumes for my cut and fill which is what I ultimately needed. some borders still arent showing up though, how can I modify the boundaries?
Joe Bouza
Well, I already did that, however when civil goes about figuring out the surface it doesn't completely go to the boundary. So when I'm doing the cut and fill computation, there are some portions by the boundaries that aren't part of the volume calculation.
Thanks for your help, sorry If these are basic questions.
Joe Bouza
Thanks for your help Mr. Bouza. I'll post on here what you helped me fix in order to further the effectiveness of these forums!
