I got this error opening a .dwg in C3D 2012. Any help would be appreciated as to steps to resolve.
Solved by ericcollins6932. Go to Solution.
Is it happening with one specific drawing or all drawings?
I haven't done a lot of FDO connections so cannot properly answer that question. So far, only the one drawing but it doesn't mean it isn't global.
By chance have you read this article on setting up the ArcSDE connection: http://gisexchange.typepad.com/blog/2010/11/adding-the-arcsde-provider-to-the-data-connect-dialog-in...
This may help with the issues you are having.
Not quite the right one but it lead me to http://gisexchange.typepad.com/blog/2010/11/top-5-list-for-troubleshooting-sde-connections.html
Thanks!
At least I was able to "nudge" you in the general direction
Let us know if you have any further questions!
