Civil 3D Forum
Error pasting surface
6 REPLIES 6
jbear0000
6261 Views, 6 Replies
I have a drawing that contains the Aerial suface. I also have a drawing which contains the EG surface. The Aerial surface is data referenced into the EG drawing. I created a new surface called EG and tried to paste the Aerial surface into it and get an error that says "Error performing edit". I have read other messages that say that this is because of the Aerial surface being a data shortcut, but I have done this many times in the past with surfaces that are data shortcuts. There should be no reason that a data shortcut surface can't be pasted.
EDIT: Also, even when both surfaces are contained in the same drawing I still get the message "Error performing edit". Any ideas on what is wrong?
6 REPLIES 6
neilyj666
in reply to: jbear0000
Some sort of circular reference going on???
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
jbear0000
in reply to: neilyj666
No, I am getting closer to figuring it out. The Aerial surface is corrupt, so I recreated it. It is not corrupt until I add the boundary around it, then for some reason it becomes corrupt.
Joe-Bouza
I have the exact same problem. I removed the data, map cleaned all the contours and points but cant get rid of the error. is you error message also report curupt surface?
the surface works fine until I try to paste it.
Joe Bouza
jbear0000
in reply to: Joe-Bouza
Yes, a corupt surface was the problem. I figured out how to fix it though. See this thread for what I did: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Corrupt-Surface-Boundary/td-p/3061526
I don't know if the problem with your surface is also the boundary, but that is a good place to start.
david.dixon
yep yep. I find that using "LINEWORKSHRINKWRAP" to produce a surface boundary often causes surfaces to be corrupt and not be able to be pasted.  The command sometimes creates a boundary that is "not planar" to world coordinates and C3D doesn't like that.
David Dixon
Senior Civil Designer
hdrinc.com/follow-us
C3D_TomR
in reply to: david.dixon
If you use LINEWORKSHRINKWRAP for objects that are all set to elevation 0, does it still corrupt the surface for pasting?
Tom Richardson
CAD Manager
Crossing the line with Civil 3D
Twitter | LinkedIn
If you find an answer to your question, please mark Accept as Solution so others can find it...
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Rail Community
