Civil 3D Forum
Error on opening a drawing
6 REPLIES 6
ebeam
656 Views, 6 Replies
I am getting a error when I open a specific drawing
FATAL ERROR: unhandled e06d7363h Exception at fel14940.
any idea what this is. I have tried to recover the drawing (message says error were found and then I get the same error)
tried the back up file ...no go
tried a back up file from 2 weeks prior, same result.
Have tried inserting as a block to a new drawing... same error.
any assistant would be greatly appreciated, this was a 95% complete project and the engineer is looking pale.
thank you in advance
Erin
6 REPLIES 6
Jay_B
in reply to: ebeam
If there are any Xrefs in play Run an Audit or Recover on ALL of those files.
Sometimes the file causing the crash can be an Xref.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
ebeam
in reply to: ebeam
Thank you.
I've tried a recover and still now success. However it will open on someone else's computer, so not sure what is up with that?
Erin Haggith
Engineering Assistant
Public Works Engineering
City of Bellingham, WA
360-778-7933
Email: ehaggith@cob.org
My incoming and outgoing email messages
are subject to public disclosure requirements
per RCW 42.56
jmayo-EE
in reply to: ebeam
Is that other computer the same OS and hardware specs?
Which OS?
If you create a new user on the PC the file crashed on and it opens then you may have a corrupt acad profile. A repair and/or a new acad profile may fix it. If the file crashes with the new user you may have hardware/driver issues. Try updating Windoz and your drivers.
John Mayo
Jay_B
in reply to: ebeam
Also, If you don't regularly clean out you Temp folder give that a shot.
Win 7 default location is: C:\Users\brubble\AppData\Local\Temp\
Close Acad & delete everything it will let you delete here.
C3D 2018.1
C3D 2016 SP4
ebeam
in reply to: ebeam
it turned out to be a missing .dll file. Something in microsoft was overwriting the file. Not sure why it was just that one drawing. Very odd.
thank you all for your suggestions
grwilson81
in reply to: ebeam
How did you fix the problem with the missing .dll file?  I am having the same problem.
Any help would be greatly appreciated.
Greg Wilson, EIT
Rail Community
