style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<jonebease> wrote in messageI
href="news:6153368@discussion.autodesk.com">news:6153368@discussion.autodesk.com...
keep getting an error when I attempt to import the attached xml file into
Storm Sewer. I have checked the flow direction and it appears to be correct.
Any other issues that would cause an error on import? Any help would be
greatly appreciated. Thanks
href="news:6153438@discussion.autodesk.com">news:6153438@discussion.autodesk.com...
can't have two pipes flowing from the same structure?
<Matt.Anderson> wrote in messageBill
href="news:6153534@discussion.autodesk.com">news:6153534@discussion.autodesk.com...
For LandXML import into Hydraflow, the limit is 4 in, 1 out.
Hydraflow by itself does not have a limit however, so if you need 5 inflow
pipes, your 5th pipe needs to be drawn in Hydraflow
itself.
Matt
