When I run my corridor I get an error message that says "Failed Target Not Found" it is for the subassembly provided by WisDOT called UrbMedian. Any ideas?
This is a standard error message that comes up when a corridor is unable to locate a surface target. Did you select a target surface for this subassembly? Is your surface large enough for the corridor to find it? Do the files from WisDOT include a help file for this sub?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
This sub only has the option to set targets for both offset/width and elevation/slope. I have targeted an alignment and a profile. There is no option to target a surface. Attached are the help files from WisDOT for this subassembly. This is the only subassembly I having an issue with. It also doesn't show up in my section editor.
Do you get the error message at every station or just a few? If it only for a few stations, does the alignment/profile exist at the station? The other thing to check is that the target alignment is on the correct side of the main alignment.
Peter Funk
I get the error message at every station. What do you mean by check that the target alignment is on the correct side of the main alignment?
