I received the message below when opening a drawing in C3D ver 2014 Is there a fix for this. All C3D functions within the drawing are disabled.
this thread. http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Drawing-created-by-a-newer-version-of-C3D/m-p/4430773...
Follow this thread. It likely has to do with corrupt objects or orphaned objects. This thread tells you how to clean it up.
Best of luck to you.
Not the same issue. The error message comes up only with the cross section sheet. I am opening the file with release 2014 which is the latest version and the version that the drawing was in before the issue. I ren recovery and audit but once the drawing is open and the error message comes up all C3D functions are dissabled.
Did you read the being civil post and follow through the recommended proceedures? If so and the problem persists, then I am at a loss as to how to advise from there.
I thought about that but the plan and profile references the same drawing and works fine.
Thank you for your help.
I will keep digging.
