Help...
I'm getting an error each time I start the program:
Error in dialog file
"C:\Program Files (x86)\AutoCAD Civil 3D 2009\support\ade.dcl", line 3696:
invalid attribute.
Symbol: "label".
Using Civil 3D 2009
64bit
Lynn
Solved by Jeff_M. Go to Solution.
I've had this happen in the past. Something changes the file (I never figured out if it was my AV, chkdsk, defrag, or what) and it is always just 1 misplaced word in the file. I've solved it a few different ways: by finding that file on the install disk and copying the entire file... by going to the bad line and figuring out what was supposed to be there (not recommended:-)...or by doing a Repair on the install.
Thanks Jeff, that seemed to work. Weird thing was when I went to look at the file the date was exactly the same as the "old" file (a 2008 date). Must have gotten corrupt but the date didn't change.?...
