Civil 3D Forum
enter name of drawing to open??
37 REPLIES 37
Message 1 of 38
124303 Views, 37 Replies
after a recent crash civil 3d now asks me to type in the full path and file name for a file i want to open after selecting the open option on the menu or toolbar.
i know there is a variable that requires re setting but i don't know how. advice gratefully recieved.
thanks!
Tags (1)
37 REPLIES 37
Message 2 of 38
FILEDIA=1
Tags (1)
Message 3 of 38
KristyMuntean
I have run into a similar situation where Civil 3D crashed and now when I try to open a file in Civil 3D it asks in the command line: "enter name of drawing to open <.>: The way I've been able to get around it is to have civil 3D open and in the start menu I search for the drawing file and double click it there to open it in Civil 3D. This is not cool. Anyone, please help!!!
Message 4 of 38
When civil3d crashes like that some parameters get set to the wrong variable. As the previous post mentions, you should Type FILEDIA at the command line and set this variable to 1. Then your open command will work as designed. GL.
Message 5 of 38
AutoCAD has lots of stupid options like this. I was frustrated by this f software. It sucks.
Message 6 of 38
andrewpuller3811
Until you want to automate something then this option comes in very handy.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 7 of 38
SCLewis
Thanks for the information on fixing this issue.
Message 8 of 38
neilyj666
in reply to: SCLewis
add the line
(setvar "filedia" 1)
to your acaddoc.lsp file and you won't see this again
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 38
SCLewis
in reply to: neilyj666
Where do I find the acaddoc.Isp file? Thanks.
Message 10 of 38
neilyj666
See message 20 in link
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Hot-Fix-isn-t-very-hot/td-p/4332149/highlight/true/pa...
Message 11 of 38
Ajilal.Vijayan
In AutoCAD command line type this
(findfile "ACADDOC.lsp")
 This should return the path of ACADDOC.lsp
Message 12 of 38
neilyj666
in reply to: Ajilal.Vijayan
This is true - if acaddoc.lsp isn't found then follow my previous post
Message 13 of 38
Hi I am not an expert by any means on CAD, however somethign has cause my computer to to that thing they're all talking about on this forum where you have to type the name of the drawing in to open it.
I have tried typing Fieldia=1 in and what ever i type it just says there is not a drawing of this name?!!?
Please help I have major project drawings to finish and i cant open them..... I also noticed I couldnt save as when recently working in CAD I had to save over what I had done.
I forgot to mention this is Civil 3D 2013
Sam
Message 14 of 38
troma
If it's asking for the drawing name, type a tilde. It's normally at the top left of the keyboard, looks like this ~
Then, when you have a drawing open, type FILEDIA in the commandline. Hit enter. Then type 1. Enter.
Mark Green
Working on Civil 3D in Canada
Message 15 of 38
in reply to: troma
Thank you sooo much!! it worked a treat!
Message 16 of 38
It works ........Thank you very much for the solution
Message 17 of 38
Hello;
What if the command line does not show up? I type in FILEDIA after the sentence: "Enter name of drawing to open <.>" and nothing happens
Message 18 of 38
antoniovinci
KBN11 wrote:
Hello;
Read the 23-01-2014 10:47 PM post, man.
Message 19 of 38
​Enter Filedia command and change value to 1
Prashant​
Message 20 of 38
johngordon6189
Just to clarify for those having difficulty understanding what you are being advised... If you happen to get the prompt for file opening or saving at the command line and not the dialog you expect to see, hit escape to exit the command and THEN type filedia at the command line and change the value to 1. Then try the open or save command again and you will see the dialog box. John
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Rail Community
