Civil 3D Forum
End of Corridor
7 REPLIES 7
Message 1 of 8
sjg
1827 Views, 7 Replies
End of Corridor
Haven't really done to much with corridors, not sure best way to tie the end of the corridor into existing ground. See image
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: sjg
One method is to draw a featureline along the end of the corridor and use a grading to the EG.
Jeff_M, also a frequent Swamper
Message 3 of 8
mathewkol
in reply to: sjg
Sjg, that depends. By your image it looks like your road just ends, perhaps to be continued ar a future date. Is this the case? Or is it supposed to tie back into an existing road which maybe isn't shown. Your answer depends on what you want to do there.
In most cases I just leave it as-is without bothering to do any cleanup. The extra work is often pointless unless it's your intent to render this project or if you NEED finished contours.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 8
sjg
in reply to: mathewkol
We are going to show it as possible future extension, but most likely will never be extended. So I would like to show finished contours
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 5 of 8
mathewkol
in reply to: sjg
Then Jeff's suggestion is about all you can do. It's pretty much what happens in the field anyway. Paste the corridor and grading surfaces into a new composite surface for your finished model.
Matt Kolberg
Message 6 of 8
Joe-Bouza
I have used a M&O sub on the end set to match slope and 0.0001 thickness.
Your Name
Message 7 of 8
Neilw_05
in reply to: Joe-Bouza
Aside from using a grading you can also treat the end like an intersection by creating an alignment representing the end of the road, sampling the corridor surface and either applying an assembly to the alignment or create a grading from a featureline generated from the alignment+profile. It's probably a prohibitive amount of work but it is an option.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 8 of 8
sjg
in reply to: Neilw_05
I will probably just go with Jeff' suggestion and generate a feature line and gradings.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Rail Community
