Valued Mentor
Valued Mentor
sjg
Message 1 of 8 (477 Views)
End of Corridor
477 Views, 7 Replies
08-31-2011 11:52 AM
Haven't really done to much with corridors, not sure best way to tie the end of the corridor into existing ground. See image
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Jeff_M
Message 2 of 8 (463 Views)
Re: End of Corridor
08-31-2011 01:02 PM in reply to: sjg
One method is to draw a featureline along the end of the corridor and use a grading to the EG.
mathewk
Message 3 of 8 (427 Views)
Re: End of Corridor
09-01-2011 02:20 AM in reply to: sjg
Sjg, that depends. By your image it looks like your road just ends, perhaps to be continued ar a future date. Is this the case? Or is it supposed to tie back into an existing road which maybe isn't shown. Your answer depends on what you want to do there.
In most cases I just leave it as-is without bothering to do any cleanup. The extra work is often pointless unless it's your intent to render this project or if you NEED finished contours.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Mentor
Valued Mentor
sjg
Message 4 of 8 (419 Views)
Re: End of Corridor
09-01-2011 06:19 AM in reply to: mathewk
We are going to show it as possible future extension, but most likely will never be extended. So I would like to show finished contours
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
mathewk
Message 5 of 8 (412 Views)
Re: End of Corridor
09-01-2011 07:06 AM in reply to: sjg
Then Jeff's suggestion is about all you can do. It's pretty much what happens in the field anyway. Paste the corridor and grading surfaces into a new composite surface for your finished model.
Matt Kolberg
Joe-Bouza
Message 6 of 8 (376 Views)
Re: End of Corridor
09-02-2011 09:44 AM in reply to: mathewk
I have used a M&O sub on the end set to match slope and 0.0001 thickness.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Neilw
Message 7 of 8 (367 Views)
Re: End of Corridor
09-02-2011 10:09 AM in reply to: Joe-Bouza
Aside from using a grading you can also treat the end like an intersection by creating an alignment representing the end of the road, sampling the corridor surface and either applying an assembly to the alignment or create a grading from a featureline generated from the alignment+profile. It's probably a prohibitive amount of work but it is an option.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Mentor
Valued Mentor
sjg
Message 8 of 8 (362 Views)
Re: End of Corridor
09-02-2011 10:28 AM in reply to: Neilw
I will probably just go with Jeff' suggestion and generate a feature line and gradings.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
