AutoCAD Civil 3D General Discussion
Active Contributor
Hokiedaddy
Message 1 of 5 (717 Views)
Empty tool palettes
717 Views, 4 Replies
12-08-2011 07:58 AM
I went to build an assembly this morning and discovered that all of my tool palettes are empty. My file path appears to be correct (C:\Users\name\AppData\Roaming\Autodesk\C3D 2011\enu\Support\ToolPalette). Does anyone know why this would happen or how I might be able to fix it without having to re-install Civil 3d?
I am using:
Civil 3D 2011
Windows 7 (64-bit)
Screeen capture is attached....
Brian
Civil 3D 2011 Version 2.1
Win 7 x64 SP1
Intel Core i5 3.33 GHz
4 GB RAM
*Expert Elite*
wfberry
Message 2 of 5 (698 Views)
Re: Empty tool palettes
12-08-2011 11:14 AM in reply to: Hokiedaddy
A "Repair of your Installation" would probably fix this.  If you are not sure:
http://mastercivil3d.blogspot.com/2011/03/repairing-civil-3d-installation.html
This is about Civil 3D 2012 but 2011 is the same process.  Should take about 15 minutes.
Bill
Active Contributor
Hokiedaddy
Message 3 of 5 (693 Views)
12-08-2011 12:59 PM in reply to: wfberry
I did a repair using the installation disks to no avail. It still shows my Imperial Tool Palette as being empty. The funny thing is that the metric and most all other palettes work fine. It is ONLY the Imperial palettes (the ones I need, go figure). Thanks for your help
Brian
Brian
Win 7 x64 SP1
4 GB RAM
*Expert Elite*
Jeff_M
Message 4 of 5 (687 Views)
12-08-2011 01:14 PM in reply to: Hokiedaddy
This was posted for C3D2007, but perhaps you can adapt it for your version:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7938671&linkID=9240697
Jeff_M, also a frequent Swamper
Active Contributor
Hokiedaddy
Message 5 of 5 (673 Views)
12-09-2011 09:45 AM in reply to: Jeff_M
So far still no progress. I appreciate all of the help and suggestions.
Brian
Win 7 x64 SP1
4 GB RAM
Announcements
Need installation help?
