cbaildon001
Message 1 of 2 (133 Views)
Ellipsoid distance label - MAPDIST
133 Views, 1 Replies
12-06-2012 12:55 PM
I would like to label line with the ellipsoid (sea level) distance instead of the default grid distance (simple join between coordinates. I can inquire for the ellipsoid distance using the MAPDIST command, but can I use this in a label style?
Cheers
Caleb Baildon
Surveyor
Opus International Consultants Ltd
Greymouth, New Zealand
Civil3D 2015 - Windows7 64bit
Sorted now. In the label settings select the property “General Segment Geodetic Distance”.
cbaildon001
Message 2 of 2 (123 Views)
Re: Ellipsoid distance label - MAPDIST
12-06-2012 03:06 PM in reply to: cbaildon001
Caleb Baildon
Surveyor
