Hi All,
Is there a way to add elevation labels at any position on a feature line without having to create a surface?
Solved by neilyj666. Go to Solution.
Yes, that is exactly it as long as the elevations update when the feature line does.
I wasn't too sure if it would because it was under the general line instead of feature line.
I just need to look up how to do an expression.
Thank you and what happened to the accept as solution button?
@Anonymous wrote:
One bummer I did find is that if you try to move the label it will not update the elevation.
That's strange. I have a General Note Label for Elevation and when I move or copy it, it will update. The bummer I see is that they don't automatically update if you edit the Featureline. You have to remember to move the label to the new elevation.
Allen
Allen Jessup
CAD Manager - Designer
This site tells you how to customize a label style so you can label elevations at any position on the feature line.
http://blog.advancedsolutions.com/civil-3d-labels-elevations-along-feature-line
Hey Jeff_M,
I've recently upgraded from LDD 2002 to C3D 2017 and wanted to let you know pretty much every item I look up to get help with your advice is always spot-on. Thanks for your postings they have been very helpful.
Jeff
Inserting elevation points on a feature creates new segments. Thus the labels will move to the new start and end points when an elevation point is added.
I draw a featureline. I learned that from John M. This is a file on creating the style I posted in the thread that Bill linked to. It should still work but I haven't used it lately.
Edit. Looks like I went too far back in the old post and answered a question from long ago. One of the dangers of necro-posting.
Allen Jessup
