Active Contributor
dgc74
Message 1 of 5 (282 Views)
Elevations change during insertion into drawing
282 Views, 4 Replies
06-21-2013 07:42 PM
I have imported a survey file.  When I insert the points into the drawing, the elevation changes to something that isn't even recognizable.  When I view the point in the survey tab, the elevation is correct, when I view the point in the prospector tab it is different. What is going on?
Jay_B
Message 2 of 5 (269 Views)
Re: Elevations change during insertion into drawing
06-21-2013 10:21 PM in reply to: dgc74
What is meant by unrecognizable? Is the difference consistent if you divide the 2 values for a few random points?
Can you give an example of what the value for point #100 is in Survey tab vs. point #100 in Prospector tab?
Posting some captions of same points for correct and incorrect may help.
Without more information, 2 possibilities that come to mind are:
1. Units in Drawing differ from those in Survey Settings.
2. Point group could have an override for the elevation value.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Active Contributor
dgc74
Message 3 of 5 (246 Views)
06-22-2013 05:05 AM in reply to: Jay_B
The elevations in the prospector tab are 250m lower than survey tab. The file is a csv file. I didn't make any changes to the coordinate system settings in the metric template.
Jay_B
Message 4 of 5 (240 Views)
06-22-2013 06:37 AM in reply to: dgc74
Verify the Drawing Settings are set to Meters by Rt clicking on dwg name on Settings tab of Toolspace>Units and Zone Drawing Units>Meters
Next verify Toolspace>Settings tab>Rt. click on "Point">Edit Feature Settings>Elevation>Unit>Meters
Do these settings both match?
Jay
C3D 2014 SP2
Active Contributor
dgc74
Message 5 of 5 (235 Views)
06-22-2013 07:50 AM in reply to: Jay_B
Yes both settings match.  I took a closer look and my Northings and Easting had shifted as well.  If I use the Import points file vs import survey data....the N,E,ELEV do not shift.
I also check the setting for the "survey" under the settings tab and it is metric as well.
