Good afternoon everybody!
I just ran into an old problem I had forgotten about. I'm doing some color bonding for a grid surface (final result is to show an inundation map of a river) and have set the number of ranges to 11, but when I click the Run Analysis button, it comes up with 12 ranges rather than 11. What's really gets me is when I run it at 10 and 12 ranges, it gives the correct number.
I have multiple surfaces and sometimes setting 11 gives the correct analysis. In some surfaces, it doesn't. I can't figure out why this is happening.
Has this happened to anybody else? I've attached screenies of what happened.
I guess I just didn't notice anymore because I stopped using the generic ranges when they added the option to select ranges by elevation intervals and datum.
There is a tool in the UKIE country kit that exports an analysis to a text file that can be edited e.g alter the colours and then it can be imported back into CIvil. I've never used it but it does work apparently.
neilyj (No connection with Autodesk other than using the products in the real world)
