Civil 3D Forum
elevation range broken
1 REPLY 1
213 Views, 1 Reply
I created a surface style to show elevation ranges, but it doesn't seem to
work. I set it to around 10 elevation ranges in Green & that worked, but
now if I try and change the style again, it has no effect at all on the
display. I tried various numbers of elevation ranges & most of the color
schemes as well as "2D solids" and "hatch solids" but it always stays in the
original green style that I created.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
1 REPLY 1
Hi Jon
The number of ranges, color scheme, etc need to be set in the "Properties"
dialog. Pick the object, right click, select properties. Once in the
Properties dialog, go to the "Analysis" tab and set the range values as
desired. Make sure you set the range type (ie, elevation, slope, contours,
etc)
Cheers
DAS
"Jon Rizzo" wrote in message
news:C1BCD552EB660F809438C0E76F2A74EE@in.WebX.maYIadrTaRb...
the
> Jon Rizzo
Rail Community
