Can anyone point me to a style that can label elevations at vertices for a 3dpolyline with elevations independent of surfaces?
Thank you.
I'm can't think of a C3d label style that will label elevations at vertices of a 3d polyline. General Line Labels don't work with 3d polylines.
One option would be to add Cogo Points at the vertices using the Home Tab>Points>Create Points Miscellaneous>Polyline Vertices options
Setting the "Prompt for elevation" parameter to Automatic first.
Another option would be to Convert the 3d Polylines to Feature Lines and use a General Line Label Style using a Text component for General Segment start or end Z options.
