i have just run an elevation analysis which by default the scheme was set to BLEU. i have changed the Scheme to RAINBOW as it good for my presentation...the challenge im having is that of the Surface table that im trying to include in my drawing but which does not reflect the RAINBOW colour as shown in the surface the colour still bleu for different elevation but i need it to be Rainbow??? Any idea how to go about this?
Francis
Solved by AlmasSuljevic. Go to Solution.
Hi Francis,
The tabel color range is determined by the colors used in the analysis (and style). So if you want to get your colors to match you would first have to edit surface style (set to rainbow), then run analysis again (colors should update to reflect rainbow) and finally, place the Surface table. That new table should be with rainbow colors.
