Debug.Print "Any text " & Right$(Format ("12345.5678","00.00"),5) & "/TBC "
Any text 45.57/TBC
Laurie Comerford
CADApps
www.cadapps.com.au
"chrisbeers" wrote in message
news:8337850.1090957890560.JavaMail.jive@jiveforum1.autodesk.com...
> I have attached this grade tag that is used by my company (just the way we
do it around here) to state the specific elevation to 2 significant digits
and the description to a 2-3 letter abbreviation of any point on a surface.
For example it would be 74.20/TBC (the TBC stands for "Top Back of Curb").
The real elevation would be somthing like 1,274.40 but we truncate the
elevation.
> I'm asking you programing gurus out there to help me program this
attribute/block to read the elevation from the "Z Position" of the block
geometry and apply it to this "ELEV" attribute to only the 4 numeric (2
before decimal and 2 after decimal) digits.
> I can handle the description fairly easy but where there are 500 of these
grade tags on a retail center plan sheet, I'm going nuts.
> Thanks in Advance.
