I created an alignment in one file. Then in another file I data shortcuted that alignment in. From there I created an existing ground profile using that alignment. Later I modifed the alignment. When I go into my profile drawing containing the existing ground profile, it did not update. I have had this happen on several projects and I can not figure out why it is not updating. My station range on the existing ground profile is set to automatic.
Any suggestions on what to check? I used to do this all the time in 2012 and never had this problem.
I am using 2013 with the latest update.
Thanks very much for any assistance offered.
I learned to get out of the habit of DS alignment and making profiles elsewhere. Trust me it will haunt you later if you keep doing it.
Do alignments and profiles in the same file.
Your Name
Your Name
If the Alignment is brought in via a Data Shortcut, even though it may say it is synchronized or not have the exclamiation icon to indicate out of date, right-click on the alignment and select synchronize to run the command again. Do the same with the surface if is brought into the drawing via a DS.
I have seen this with profiles that are in a different drawing via DS, they may show up with no length, but running the synchronize command will bring it back. This can be an issue with P&P sheets being batch plotted if the P&P drawing is not opened first so the synchronize can be done.
Thank you for your suggestion Drew, I all ready made sure I resynced everything just incase. But that didn't work either.
I am wondering if there a computer you have access to with C3D 2013 and NOT the lastest update? Open the drawing in that version and see if the profile updates. This issue of not updating seems to be new with the service pack for C3D. Please let me know if this is it. The issue did seem to be "random" where some computers did update and others did not, but the more I check into the configurations that have the issue, the more it points to the service pack.
I don't know of a way to just remove the service pack, unless you happen to have created a restore point before installing it. To remove it you will go through uninstalling C3D and reinstalling without the service pack being applied. If anyone knows different, please share.
I will give this a try when I can squeeze in the time. I will report back my findings.
Thank you for your help.
