I have an existing alignment defined and need to change the design speed from 60mph down to 25mph. When I go into the Alignment Properties, Design Criteria tab, C3D won't let me edit the design speed. I can add a new design speed, but I can not edit the station or design speed for it either. If it matters, the Constraint Editing tab has the Lock all parameter constraints checked and grayed out.
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
