Civil 3D Forum
Editing the Design Speed of an existing alignment
2 REPLIES 2
jfengineering
859 Views, 2 Replies
I have an existing alignment defined and need to change the design speed from 60mph down to 25mph. When I go into the Alignment Properties, Design Criteria tab, C3D won't let me edit the design speed. I can add a new design speed, but I can not edit the station or design speed for it either. If it matters, the Constraint Editing tab has the Lock all parameter constraints checked and grayed out.
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
2 REPLIES 2
Joe-Bouza
in reply to: jfengineering
Is it possible you are trying to edit a Data Shorcut of the alignment? If so go to the source drawing to edit
Your Name
jfengineering
in reply to: Joe-Bouza
That's it! Those things are going to be the death of me! 🙂 Thanks!
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
Rail Community
