AutoCAD Civil 3D General Discussion
Active Member
post
Message 1 of 4 (178 Views)
Editing Feature Lines with the Grading Elevation Editor
178 Views, 3 Replies
02-01-2014 02:24 AM
Is there any way to hold the focus on the selected points in the Grading Elevation Editor?
When I select some points and use raise once, the points beein deselected. And then I have to select the points again if I want to rise more.
-Or is there any easier solution to select a point or some point on a feature line and raise/lower then fast and easy by step?
Rune
Valued Contributor
Citadel2012
Message 2 of 4 (155 Views)
Re: Editing Feature Lines with the Grading Elevation Editor
02-01-2014 07:05 AM in reply to: post
Grab a feature line and the feature line editor ribbon should pop up. Hit "edit elevations" and click the first small icon on the upper left, "quick elevation editor." This allows you to set the elevation at each P.I./elevation point, as well as grade in/out. Hope this helps.
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Active Member
post
Message 3 of 4 (101 Views)
02-06-2014 12:35 PM in reply to: Citadel2012
thanks, but it's still a slow way to edit and try.
I hope it should be a way to hit a key to raise a point fast and easy. now you have to enter the measurement each time. That's too slow...
Rune
*Expert Elite*
jmayo
Message 4 of 4 (89 Views)
02-06-2014 02:45 PM in reply to: post
Try keeping the CTL or SHIFT key held down after making a multiple selection and keep the key help down while you click the buttons to edit.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
