i've got an expression set up for top, eop and throat elevations for a structure. now i need to edit it for a different type structure. i can't see how to edit it. is it possible? thanks.
Solved by c.bergthold. Go to Solution.
You can edit expressions by right clicking in toolspace (see attachment). If you want to maintain the original expression and structure label style you will need to create a new expression and new label style.
good lord. that window at the bottom wasn't visible. i thought it would pop up when i picked the 'expressions' label. you have to grab it and slide it up. thanks.
