Civil 3D Forum
Editing a vertical curve
7 REPLIES 7
Message 1 of 8
GrantT-LS
3228 Views, 7 Replies
I have an existing vertical curve profile and the parameters have changed. A straight profile editing works great but I am having problems with the curve.
Tim Grant
Civil 3D 2022.1.3
Windows 10 Professional
Intel Core i7-10700 CPU @ 2.9 GHz
16 GB, 64-bit
7 REPLIES 7
Message 2 of 8
Jay_B
in reply to: GrantT-LS
Tim,
More information is needed re: how your attempting to edit the Vertical Curve and what specific problem your running into.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 8
GrantT-LS
in reply to: Jay_B
Jay
I created the Vertical Curve with the "Fixed Vertical Curve (Two Points, Parameter). Now I need to change the beginning and ending elevations with a new K value. and I will be eliminating a vertival curve further down the profile. I'm trying to edit the curve by selecting the profile and using "Geometry Editor", and trying to use "Move PVI". I just now saw "Insert PVIs - Tabular" and "Raise/Lower PVIs" in the middel of the "Profile Layout Tools" dialog box.
Tim Grant
Civil 3D 2022.1.3
16 GB, 64-bit
Message 4 of 8
wfberry
I believe that the fixed vertical curve may lock you out of what you want to do.  I have always used the free vertical curve with no problem.
Bill
Message 5 of 8
Joe-Bouza
I agree with Bill use a free curve, but is you have to edit any curve I like the entity editor on the edit
Joe Bouza
Message 6 of 8
GrantT-LS
in reply to: Joe-Bouza
So what I take from the last posts if I can't edit my existing curves I will need to redraw them using the "free curve" and reassociate my templates and crossections?
Tim Grant
Civil 3D 2022.1.3
16 GB, 64-bit
Message 7 of 8
callen
False, retain the same profile but just delete the entity or pi.  This will allow you to insert the free vertical curve without the extra work of re-targeting
Message 8 of 8
GrantT-LS
in reply to: callen
Thanky you to all.
Tim Grant
Civil 3D 2022.1.3
16 GB, 64-bit
Rail Community
