I reposted it. The original file opens fine on my machine. I zipped it, I
hope it helps. Thanks.
"Landman" wrote in message
news:4816644@discussion.autodesk.com...
> unable to open. drawing file not valid. You might want to try to re-post.
> "Robert Skrobot" wrote in message
> news:4816486@discussion.autodesk.com...
>> I have placed a file in the coustomer files news group, it is an attempt
> to
>> regrade an existing road and add a ditch on either side of the roadway.
> The
>> problem that I am running into is when the road passes the high point. As
>> can be seen from the drawing, the contours extend 100' outside of the
> road.
>> It appears that the surface created on the corridor has some extra tin
>> lines...Can these be deleted? Am I doing something else wrong? Thanks.
>> Robert Skrobot
