Civil 3D Forum
Edit Units for Pipe Properties
5 REPLIES 5
Dixter
1045 Views, 5 Replies
I am setting up a parts list using The Metric Catologue. In the Pipe Properties the Pipe Diameter shows mm but the Minimum Curve Radius shows inches. The Units are Greyed-Out. Is ther a way to edit these Units?
Kirk Dixon
Dixter
5 REPLIES 5
SethHall
in reply to: Dixter
Did you by chance start an imperial drawing and point to the metric catalog with SETNETWORKCATALOG?
Seth Hall
Product Owner
Model Builder
Dixter
in reply to: SethHall
No, All my Templates have a Metric Base. We never work in Imperial here. [KRD-EMAIL SIG]
Dixter
SethHall
in reply to: Dixter
After a little poking around, the unit information is stored in this file: AeccPartParamCfg.xml Typically located here:
C:\ProgramData\Autodesk\C3D 2013\enu\Pipes Catalog\Aecc Shared Content
<AeccDfParameter name="MCR" desc="Minimum Curve Radius" context="MinCurveRadius" index="0" datatype="Float" usage="Double_Distance" unit="in" visible="True" internal="True"/>
You should be able to change the unit value above and it should populate in Civil 3D.
Seth Hall
Product Owner
Model Builder
Dixter
Thank you very much, that worked. Appreciate it!! [KRD-EMAIL SIG]
Dixter
SethHall
in reply to: Dixter
Great!! Glad to help!
Seth Hall
Product Owner
Model Builder
Rail Community
