kdixon
Message 1 of 6 (264 Views)
Edit Units for Pipe Properties
264 Views, 5 Replies
01-15-2013 04:13 PM
I am setting up a parts list using The Metric Catologue. In the Pipe Properties the Pipe Diameter shows mm but the Minimum Curve Radius shows inches. The Units are Greyed-Out. Is ther a way to edit these Units?
Kirk Dixon
After a little poking around, the unit information is stored in this file: AeccPartParamCfg.xml Typically located here:
C:\ProgramData\Autodesk\C3D 2013\enu\Pipes Catalog\Aecc Shared Content
<AeccDfParameter name="MCR" desc="Minimum Curve Radius" context="MinCurveRadius" index="0" datatype="Float" usage="Double_Distance" unit="in" visible="True" internal="True"/>
You should be able to change the unit value above and it should populate in Civil 3D.
Product Support
SethHall
Message 2 of 6 (240 Views)
Re: Edit Units for Pipe Properties
01-17-2013 09:03 AM in reply to: kdixon
Did you by chance start an imperial drawing and point to the metric catalog with SETNETWORKCATALOG?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
kdixon
Message 3 of 6 (236 Views)
01-17-2013 09:27 AM in reply to: SethHall
No, All my Templates have a Metric Base. We never work in Imperial here. [KRD-EMAIL SIG]
Product Support
SethHall
Message 4 of 6 (221 Views)
01-18-2013 12:56 PM in reply to: kdixon
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
kdixon
Message 5 of 6 (201 Views)
01-21-2013 07:53 AM in reply to: SethHall
Thank you very much, that worked. Appreciate it!! [KRD-EMAIL SIG]
Product Support
SethHall
Message 6 of 6 (189 Views)
01-22-2013 05:55 AM in reply to: kdixon
Great!! Glad to help!
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
