Civil 3D Forum
Edit Surfaces
14 REPLIES 14
Message 1 of 15
petelien
464 Views, 14 Replies
Edit Surfaces
I have created a EG surface, and an OB surface. My OB surface some times goes above my EG surface which its not supose to do. Is there a way i can make my OB layer match my EG layer?
14 REPLIES 14
Message 2 of 15
in reply to: petelien
Sorry, what's an OB surface?
Message 3 of 15
neilyj666
Yes - knowing what an OB surface is (and how it was originally derived) would be useful
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 15
ThomasBHansen__
in reply to: neilyj666
I have no idea what an OB surface is, but I would probably guess that what you are looking for is "minimum distance between surfaces" found in the analyze tab.
This will give you some 3d polylines where the different surfaces cross each other that you can use as boundries. And then You just paste them together 🙂
But this is all just a wild guess since I dont really know what an OB surface is 🙂
Landscape Architect & technical expert
Message 5 of 15
neilyj666
in reply to: ThomasBHansen__
My guess is that the OB surface (Overburden) is a subsurface stratum that has been modelled incorrectly and is appearing above the EGL.
There is a fairly easy fix for this if that is indeed what has happened
Message 6 of 15
petelien
OB is Overburden.  I created a surface from a topo shape file i brought in. and then i created an overburden surface with bore hole data, using the geotechnical module. My Overburden is some spots is sitting above my topo surface. I was just wondering if there was a tool i could use to "clip" the overburden surface to match my topo surface.
Message 7 of 15
neilyj666
You need to be very wary of surfaces created by the geotechnical module as they are not what I would call any good for any detailed analysis.
I'd suggest you follow this method http://civilintentions.blogspot.co.uk/2012/05/creating-geological-surfaces-from.html
Message 8 of 15
Sure, make a FL at the toe of OB >> extract elevations for EG then add to OB
Message 9 of 15
Please give me a little more how to on the FL at the toe of OB. I am not sure i know how to do that. Please, Thank you!
Message 10 of 15
I'm assuming the overburden layer is a pile on top of eg, correct?
If so, you should have an outter boundary to the OB, no?
If so, turn it into a FL and assign EG elvations to it. I'm not in front of a WS now so bare with me.
grip the FL>> the ribbon should adjust; in the upper right there is a palette of FL editing tool picj the one that has the surface icon = elevations from surface>> pick the FL annswer yes to intermediate point>> add the FL to OB and now OB meets EG
Message 11 of 15
what is a FL and how do I turn my outter boundary into one? Sorry!
Message 12 of 15
MarySeufert
FL = Feature Line
Home Tab->Create Design Panel->Feature Line->CREATE FEATURE LINE FROM OBJECTS
To add surface elevations to new feature line: Select Feature Line, From Contextual Ribbon Tab->Edit Elevations->pick Elevations from Surface button. Or use command FeaturesElevsFromSurf
EXPERT ELITE MEMBER
Message 13 of 15
petelien
in reply to: MarySeufert
ok, I created a FL and added the elevations from my EG surface. I tried to add the FL to my OB surface as a breakline? and it didn't change anything, I am guessing that was wrong, so how do I add the FL to my OB surface?
Message 14 of 15
neilyj666
You'll still need to trim surfaces as all you have done thus far is add a line at the common interface level.  I'd advise you to follow the method in my earlier post as this gives the required results.
Message 15 of 15
Ah the geotech module; I'll have to look into this as I haven't tried it out yet.
Rail Community
