I have created a EG surface, and an OB surface. My OB surface some times goes above my EG surface which its not supose to do. Is there a way i can make my OB layer match my EG layer?
I have no idea what an OB surface is, but I would probably guess that what you are looking for is "minimum distance between surfaces" found in the analyze tab.
This will give you some 3d polylines where the different surfaces cross each other that you can use as boundries. And then You just paste them together 🙂
But this is all just a wild guess since I dont really know what an OB surface is 🙂
OB is Overburden. I created a surface from a topo shape file i brought in. and then i created an overburden surface with bore hole data, using the geotechnical module. My Overburden is some spots is sitting above my topo surface. I was just wondering if there was a tool i could use to "clip" the overburden surface to match my topo surface.
You need to be very wary of surfaces created by the geotechnical module as they are not what I would call any good for any detailed analysis.
I'd suggest you follow this method http://civilintentions.blogspot.co.uk/2012/05/creating-geological-surfaces-from.html
Sure, make a FL at the toe of OB >> extract elevations for EG then add to OB
Please give me a little more how to on the FL at the toe of OB. I am not sure i know how to do that. Please, Thank you!
FL = Feature Line
Home Tab->Create Design Panel->Feature Line->CREATE FEATURE LINE FROM OBJECTS
To add surface elevations to new feature line: Select Feature Line, From Contextual Ribbon Tab->Edit Elevations->pick Elevations from Surface button. Or use command FeaturesElevsFromSurf
ok, I created a FL and added the elevations from my EG surface. I tried to add the FL to my OB surface as a breakline? and it didn't change anything, I am guessing that was wrong, so how do I add the FL to my OB surface?
You'll still need to trim surfaces as all you have done thus far is add a line at the common interface level. I'd advise you to follow the method in my earlier post as this gives the required results.
