Solved by C3D_RickGraham. Go to Solution.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<C3D_RickGraham> wrote in messageOk,
href="news:6104136@discussion.autodesk.com">news:6104136@discussion.autodesk.com...
so I'm an idiot. I figured it out. I better go home and start the day over!
geesh!
<C3D_RickGraham> wrote in messageJoe,
href="news:6104255@discussion.autodesk.com">news:6104255@discussion.autodesk.com...
The
profile was created using 'Create Profile from Surface' Of course when you
create from a surface, there is nothing to edit! That is my 'Duh' moment
today.
Rick
"dreed122" wrote in messageI
href="news:6105658@discussion.autodesk.com">news:6105658@discussion.autodesk.com...
am having the same problem. I can do the exact same thing in 2008 and the
buttons are not grayed out. If it is because I'm using "Create Profile from
Surface", what would be the correct way to create a profile that I can
edit.
I also frequently experience this and must restart Civil 3D to edit a profile.
Screenshot from Civil 3D 2014, error still exists.
In 2016 too................still.
I have experienced this before in a regular surface. Close C3D and reopen always solves it. i have experienced it from version 2012 to 2015.
Anno Domini 2017 and...? Nothing changed 🙂
Hello everybody - my first post here 🙂
Yes - nothing has changed.....who would have guessed...;)
I have the same.
All we can do is not buy autodesk products until they stop developing soft with bugs for a moment and first fix all bugs like this. For me it is priority.
Like all of you I had the same issue. I tried something pretty fast and it worked (still, I don't know if it will ALWAYS work...).
So here is exactly what I did:
Select a grip, then Right click, then select enter (i'm french so here it's Entrer), and left click inside your profile view to move your profile geometry.
After that I could use all the editing functions ogf the dialog box again.
Worth a try next time it happens. That is if I can remember this post. LOL
Thanks for the tip! 🙂 I'll try it at some stage. It would be nice to know what is causing the problem in the first place 🙂
