Civil 3D Forum
Edit Profile Geometry greyed out?
22 REPLIES 22
Message 1 of 23
C3D_RickGraham
15092 Views, 22 Replies
G'morning all,
I have a strange thing that all of a sudden started happening. If I Rt-Clk on a surface on a profile and select Edit Profile geometry, the dialog box comes up, but almost every option in there is greyed out!
This is not drawing-specific, not is it machine specific. Can someone point me to some possible solutions?
See attached pic.
Rick
Rick
coauthor Mastering Civil 3D 2012
I blog at http://simplycivil3d.wordpress.com
22 REPLIES 22
Message 2 of 23
Ok, so I'm an idiot. I figured it out. I better go home and start the day over! geesh!
Rick
Message 3 of 23
in reply to: C3D_RickGraham
Rick please share (however silly it may
seem)
Thanks, Joe
Joseph D. Bouza, P.E.
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
NIVDIA Quadro FX 1700 (512MB)
The mantra of a former Flamer:
If you are forced to eat an Elephant, don’t complain about it; Take one
bite at a time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." 😮
A reminder taken
from Graphics Solution Providers' Calendar
page
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Ok,
geesh!
Message 4 of 23
Joe,
The profile was created using 'Create Profile from Surface' Of course when you create from a surface, there is nothing to edit! That is my 'Duh' moment today.
Rick
Rick
Message 5 of 23
We all have'm <G>
I read these to learn from mistakes as well as
success's. As I'm sure others do.
Thanks, Joe
Civil 3D 2008
LDT 2008
Win XP pro
v 2002,
sp 2
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB
RAM
bite at a time.
In
A reminder taken
page
Joe,
The
today.
Rick
Message 6 of 23
ACSI_Chuck
Quick fix...
Exit out of Civil 3d and re-open.
Should have access to your layout toolbar.
Cheers,
Message 7 of 23
UTE_H20
I am having the same problem. I can do the exact same thing in 2008 and the buttons are not grayed out. If it is because I'm using "Create Profile from Surface", what would be the correct way to create a profile that I can edit.
Message 8 of 23
It must be a Static profile in order to edit it. If you must
edit your surface profile, change the Update Mode under the Profile
Properties to Static.
I
edit.
Message 9 of 23
dbussie
in reply to: ACSI_Chuck
Closing Civil 3d and reopening worked for me.  Thank you!
Message 10 of 23
neilyj666
in reply to: dbussie
....and 4 or 5 years on has this bug been rectified? No is the answer, but as it is not repeatable on demand I guess it's difficult to track down the cause
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 11 of 23
csevers
in reply to: neilyj666
I also frequently experience this and must restart Civil 3D to edit a profile.
Screenshot from Civil 3D 2014, error still exists.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
Message 12 of 23
neilyj666
in reply to: csevers
....and it is still in 2015
Message 13 of 23
CADmgrMike
In 2016 too................still.Smiley Mad
Mike Porter
https://provostandpritchard.com/
Message 14 of 23
SamEAS
in reply to: UTE_H20
I have experienced this before in a regular surface. Close C3D and reopen always solves it. i have experienced it from version 2012 to 2015.
"It was just a check-box"
Please remember to use the Kudos and Accept as Solution if I have helped you!
Student of Civil Engineering
Washington Engineering Institute
Help us spread the word on WEI, or learn more about our goal! Visit us at www.weiedu.org
Message 15 of 23
jbedkowski
in reply to: SamEAS
Anno Domini 2017 and...? Nothing changed 🙂
Hello everybody - my first post here 🙂
Message 16 of 23
neilyj666
in reply to: jbedkowski
Yes - nothing has changed.....who would have guessed...;)
Message 17 of 23
Ronczez
in reply to: SamEAS
I have the same.
All we can do is not buy autodesk products until they stop developing soft with bugs for a moment and first fix all bugs like this. For me it is priority.
Message 18 of 23
Empstrike0
in reply to: Ronczez
Like all of you I had the same issue. I tried something pretty fast and it worked (still, I don't know if it will ALWAYS work...).
So here is exactly what I did:
Select a grip, then Right click, then select enter (i'm french so here it's Entrer), and left click inside your profile view to move your profile geometry.
After that I could use all the editing functions ogf the dialog box again.
2017-10-19 16_06_02-Autodesk AutoCAD Civil 3D 2016 - [Model_C3D_Rameau_Ventil_Fourreaux_HT.dwg].png
Message 19 of 23
CADmgrMike
in reply to: Empstrike0
Worth a try next time it happens. That is if I can remember this post. LOLSmiley Happy
Mike Porter
Message 20 of 23
jbedkowski
Thanks for the tip! 🙂 I'll try it at some stage. It would be nice to know what is causing the problem in the first place 🙂
Rail Community
