Nevermind.. I just tried what you were saying. I got the same results as
you. Even though the point datum was changed, there was no notification of
a surface definition change and a need to rebuild. Is it possibly because
the "point group" didn't change?
"Ron Mills"
wrote in message
news:5008126@discussion.autodesk.com...
Do you have automatic rebuild enabled?
wrote in message news:5008007@discussion.autodesk.com...
Minor issue here when editing point datum elevations.
The edited points are referenced in a point group, which in turn is used to
build a surface.
Neither the point group nor the surface displays the exclamation flag
indicating that there are changes. If you move a point (xyz) used in a
surface then this means the surface needs to update but there's no flag.
Andrew
