Civil 3D Forum
Edit label text in Parcel Label
9 REPLIES 9
Message 1 of 10
AllenJessup
2715 Views, 9 Replies
Is there a way to "Edit Label Text" in a Parcel area label? Similar to the way you can edit it in other styles.
Allen Jessup
CAD Manager - Designer
9 REPLIES 9
Message 2 of 10
AllenJessup
in reply to: AllenJessup
I think the answer is NO. If someone could confirm that, I'd appreciate it.
What's happening is that our Surveyor wants any parcel area of 1 Acre of less to be labeled as Acre not Acres. i.e.
46.24 Acres   -   0.18 Acre
I thought that I might be able to do that with an Expression. But you can't use static text in an expression.
What it looks like I'm going to have to do is create a separate Label Style for parcels of 1 acre or less. I think that's a messy way to do it, but I don't see any other choice right now.
Allen Jessup
Message 3 of 10
stacy.dunn
You could use an expression to check the acreage and return a text size (plotted height / 12).  Your label would have to have two components that use the expression.  One will have Acres and the other will be Acre.
if({Parcel Area}<1,0.0001,0.8333)
Stacy Dunn
Message 4 of 10
Actually Allen,
Let me see if I can make your day.
As you have seen the initial label for a parcel has limitations due to the fact that it is used to pick the parcel itself when you don't want to edit the parcel segments.
However a second area label can be placed on a parcel and this one is text editable.   So add the second one edit it to suit how you want it and set the initial label to no display.
Message 5 of 10
AllenJessup
in reply to: stacy.dunn
Thanks. I'll have to take a look at that. I've already created a new Label Style so I could publish the plan. But I'd like to clear this up for the future and add it to our template.
Allen Jessup
Message 6 of 10
AllenJessup
That's interesting! I'll have to try that also.
Allen Jessup
Message 7 of 10
AllenJessup
That works well. I think I'll do it that way for now. I still have to try Stacy's idea. That might be a better long term solution since it would be automatic.
Allen Jessup
Message 8 of 10
stacy.dunn
Allen,
You will need two expressions and two components for a single label.  It will be automatic but the only downside is that the dragged state needs to be "as composed" so you will have to add a manual leader if needed.  See the attached drawing for an example.
Stacy Dunn
Message 9 of 10
AllenJessup
Thanks Stacy,
I'm working on duplicating your style. I'll let you know how it goes. I may have some questions. Now that I see it in action. I understand about the text heights.
Allen Jessup
Message 10 of 10
AllenJessup
Got it. If I hadn't fumbled a decimal point in one of the expressions, I would have been done sooner. Thanks you, Stacy, That's a nice addition to our parcel labels.
Allen Jessup
Rail Community
