Active Member
marirf
Message 11 of 19 (176 Views)
Re: Edit grading
10-25-2012 12:06 PM in reply to: mathewk
Hi!
I´m going to attach an image that shows what I´m trying to say!
Mariana
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2015 - Infrastructure Design Suite
Windows 7 64 i7 47700 @3.40GHz 8GB Ram GeForce GT 630
mathewk
Message 12 of 19 (170 Views)
Re: Edit grading
10-25-2012 12:52 PM in reply to: marirf
Transitions have nothing to do with 2 grading objects intersecting as in your image.  You have the "Points" option only if you have a gap between gradings on the same feature line.  The original quesiton was about how to create a transition when te feature line has a single continuous grading on its entire length.  Two diferent techniques.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Neilw
Message 13 of 19 (166 Views)
Re: Edit grading
10-25-2012 01:03 PM in reply to: marirf
Your image shows what appears to be a corridor and a grading. The grading overlaps the corridor. So I gather you want to transition the grading to the corridor or vice versa. That will require a bit more convoluted workflow.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Member
marirf
Message 14 of 19 (163 Views)
Re: Edit grading
10-25-2012 01:11 PM in reply to: Neilw
No, I wanted to show you that the option [Points] appears. It is really only one feature line, the one that is selected. It is targeting the natural ground, the corridor is independent and has nothing to do with my problem.
Mariana
Joe-Bouza
Message 15 of 19 (148 Views)
Re: Edit grading
10-25-2012 01:28 PM in reply to: mathewk
Hi Matt
Any chance this video can be summed up in a few words for those that do not have access to youtube at work?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
mathewk
Message 16 of 19 (145 Views)
Re: Edit grading
10-25-2012 01:33 PM in reply to: Joe-Bouza
Let's say you have a building pad that dayllights at 2:1 all the way around.  Click the add transition button and specify a point, accept the default or set different slopes.  Add additional transition points and set their slopes accordingly.
Matt Kolberg
Joe-Bouza
Message 17 of 19 (143 Views)
Re: Edit grading
10-25-2012 01:33 PM in reply to: marirf
Mariana,
The image helps but the description is fuzzy. If I had to guess you invoked the transition option after the grade to surface was completed and c3d thinks you have two gradings to go between.
Might I suggest starting over and put the transitions where you want. from what I can see the grading doesnot look too complex to redo
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Neilw
Message 18 of 19 (135 Views)
Re: Edit grading
10-25-2012 01:51 PM in reply to: Joe-Bouza
It is not necessary to start over. You can insert a transition into a grading even if it is closed. Using the grading layout tools, select the transition tool and when it prompts for a location, pick any location in the grading and it will insert a transition. You can then delete it which will leave a gap in the grading. From there you can edit the gradings on either side of the gap and then fill it in with a new transition.
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 19 of 19 (128 Views)
Re: Edit grading
10-25-2012 03:01 PM in reply to: Neilw
Thanks for the motivation
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
