Active Member
marirf
Message 1 of 19 (297 Views)
Edit grading
297 Views, 18 Replies
10-25-2012 07:17 AM
Hi everyone,
I´m having some trouble about edit grading and hope that someone can help me.
I´ve done a grading "applying to entire lenght" but after done that I realized that I needed to do some located contentions. Is it possible to edit the grade for not applying it to entire lenght?
When I go to the modify tab, edit grading, it does not appears the option "apply to entire lenght?"
Mariana
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2015 - Infrastructure Design Suite
Windows 7 64 i7 47700 @3.40GHz 8GB Ram GeForce GT 630
dasindog
Message 2 of 19 (294 Views)
Re: Edit grading
10-25-2012 07:35 AM in reply to: marirf
I don't believe so. From what I remember once you choose to grade from the entire length you are stuck. You will need to delete the grading and use new options.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Active Member
marirf
Message 3 of 19 (291 Views)
Re: Edit grading
10-25-2012 07:41 AM in reply to: dasindog
That´s what I thought so,
unfortunately, my surface is "stitched" on the inside, if I do a new grade, with a new infill I´ll lose all my work
Mariana
mathewk
Message 4 of 19 (282 Views)
Re: Edit grading
10-25-2012 08:15 AM in reply to: marirf
You are by no means stuck.  You can definitely make edits to it.
http://www.youtube.com/watch?v=WbuCVV_hreI&list=UU_5gUiM33gZ5nCshE0gp-jA&index=40&feature=plcp
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
dasindog
Message 5 of 19 (268 Views)
Re: Edit grading
10-25-2012 09:37 AM in reply to: mathewk
It still amazes me of all the little things I don't know about that can make such a big deal in a workflow. Thanks, Matt!
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
mathewk
Message 6 of 19 (266 Views)
Re: Edit grading
10-25-2012 09:39 AM in reply to: marirf
Any time.
Matt Kolberg
Active Member
marirf
Message 7 of 19 (250 Views)
Re: Edit grading
10-25-2012 11:30 AM in reply to: mathewk
Hi!!! Thank you so much for that solution!
But I still have a question about the creation of a transition. In autocad C3D 2013, it offers me an option to create transition, after that, if you press enter, it won´t work, because I only have 1 grading, no slope difference. Also, it offers me the option of [Points], so, I press P, and create a transition, is that correct?
I ask that because I thought that the creation of a transition was only used when I had different slopes at the same grade encountering each other.
Mariana
Joe-Bouza
Message 8 of 19 (243 Views)
Re: Edit grading
10-25-2012 11:47 AM in reply to: marirf
I cant access Youtube here. What is the solution?
The transition tool can create a slope transition on the fly or expect at least two gradings along the feature line seperated by a gap. grading 1 would have slope 1 , grading 2 slope 2 and the transition flow btween them
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
mathewk
Message 9 of 19 (241 Views)
Re: Edit grading
10-25-2012 11:48 AM in reply to: Joe-Bouza
Just add a transition, actually a few of them.
Matt Kolberg
mathewk
Message 10 of 19 (232 Views)
Re: Edit grading
10-25-2012 12:03 PM in reply to: marirf
I don't know what you mean Mariana.  It's working in 2013 the same way as it is in my video.  I have no "P" option when adding transitions.
Matt Kolberg
