I am trying to find out if there is a way to change the code for the Corridor Section Points Report. Please see attachment. In page 1 of the attachment you will see the names that we prefer for the different zones in our assembly as per our Standards. On page 2 is the default names that C3D spits out as defaults (under String Cut). We are running C3D 2012.
Not sure if / how the values can be changed in report settings one workaround is to Copy / Paste Report from browser into Excel and find replace as desired in Excel.
Yes, thats what we've been doing but it can get tedious when you have a centreline alignment, a crown alignment, two edge of pavement alignments and the corridor is a couple kilometres long. If we could change the code to match our Standards it would cut down on editing. Also, the points don't come in with the highest elevation first in the list and then down to the lowest elevation. Again, see attachment. This is very confusing out in the field.
You could make your own subassemblies in the subassembly composer. You can then assign any point codes you want.
