Hi Forum,
i have georectified image in ecw file which is rectified from ER Mapper in the meter unit. When i inserted into drawings which has same coordinate system with ecw file in Autodesk civil 3d 2006, the image can be displayed and orientated accurately.
While i try to open the same drawing and try to insert the same image with Autodesk Civil 3D 2006 (Raster_Design_2007_OE.exe is installed), the image can not be combined correctly (miss-orientation and miss-scale).
Before inserting image, I set drawing's unit in meter then after image is inserted drawing's unit changes to unitsless.
Thanks for any comments.
znl
