Member
jagreve
Message 1 of 4 (309 Views)
ECW image shifting within paper space
309 Views, 3 Replies
12-02-2012 08:24 PM
Problem: ECW image shifting within paperspace layout. Problem only with viewports which have been twisted.
Computer:
Windows 7 64bit
32gig ram
Quadro 2000 (on the supported list)
Using Civil3d 2012
Have tried recovering... moving the geometry is not an option.
Have also tried toggling "Projection" on and off as suggested in other threads
This seems to have been a long standing issue and its surprising there yet seems to be a fix
Have made the same post in an AutoCAD 2011 as a reply to a board on the same issue. Link: http://forums.autodesk.com/t5/AutoCAD-2011/Image-shifting-in-Paper-Space-quot-Autocad-2011-quot/m-p/...
Valued Mentor
KirkNoonan
Message 2 of 4 (281 Views)
Re: ECW image shifting within paper space
12-03-2012 04:41 AM in reply to: jagreve
Try switching the insertion method (Map Insert vs.. FDO attach). There is an outside chance that it might help. Otherwise, open a support request. You will inevitably get the official "known issue" response, but if there are enough of them on the pile they might eventually fix it.
*Pro
dgordon
Message 3 of 4 (276 Views)
12-03-2012 05:11 AM in reply to: jagreve
I've seen the image shifting when zooming in and out before.    As long as it plots the same way every time it's only been a annoyance not a problem.   It would be nice if they fixed it, but it's not high on my priority list.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Mentor
KirkNoonan
Message 4 of 4 (275 Views)
12-03-2012 05:17 AM in reply to: dgordon
Therein lies the problem - Sometimes it looks fine, but it always plots incorrectly Kirk Noonan Carter Associates, Inc.P (772) 562-4191 F (772) 562-7180
